Panel View 900 problem
We have a Panel View 900 designed for use with the DH 485 network. One of our students mistakenly plugged out ethernet into it and the unit doesn't work now. The school budget will not allow us to send it out for repair or much less a replacement. Does anyone know of a possible repair that can be done?
RE: Panel View 900 problem
Ethernet and DH-485 use similiar voltage levels. I would look for a mechanical defect in the connector before electrical. Are the pins bent inside the connector?
