Losing links in a product
I just realized that if I create a part inside a product, generate some links to other parts in the product etc... then I remove it accidentally from the product "context", when i try to put it back, the links are broken, or not found!!
How can i put them back???
RE: Losing links in a product
Select OK, and your context should be fixed. You can tell by the color of the gear in the icon - green means you are "in context"
Are you using published links?
If you are linked to Published Elements, then your links will be more stable, and there will be a much better chance of the Define Context working.
What I also have been trying is to copy and paste breaking link to get a part that is equal to the one I have in the product but with slight changes, but keeping the same links. The problem is that when i try to modify it is says that is not in its context, when its insaide the same product!!, and that i have to define its contextual links, which i tried with no succes. Is there any other way to do that.
And one more question... What means to publish an element?? what is that used for???
1. copy original part & paste special/break link into the product
2. change properties to rename the part
3. Define contextual links
4. replace external references as required
5. update and save the product & parts
The black circle could indicate several things: the replaced element is in a child part (and would cause a loop), or it's not published, or it's not the correct type of geometry, or (most likely) you have a secondary instance of the part (brown gear) and are not allowed to add/replace external references.
1. Publish identifies elements that are intended to be used as master geometry
2. Published links are maintained when the parent part is replaced or renamed
One thing i realizad is that i was working in cache mode, and i had only a subproduct in design mode which meant that the main product to where the part was linked was not active, and i was not being able to define the contextual links. if all the product is in design mode then it worked.
E.g. A link created as described by lordralife at the top of this thread it's important that the product is active and not one of the parts.
Make the product active (doubble click left mouse button on it) and then right-click on the part that you want to define and choose Components/Define Contextual Link.
As written earlier in this thread, defining context and keeping links is easier with published references.
This method only works if you isolate all links, some links are embedded in sketches and do not appear in the external elements list.
