Residential spread footings rebar
I have to add 2 spread footings to the center of my house, one to hold 9,000 lbs and the other 23,000 lbs. I have a spread footings design using a rebar size I can't get, so I am looking for advice on how to do the footings using 1/2" diameter rebar.
The soil capacity is 3000 psf. The footing for 9000 lbs will be 2'x 2' and the footing for 23,000 lbs will be 3' x 3'. Both would be 1' thick. What would you recommend for spacing for 1/2" rebar?
RE: Residential spread footings rebar
What was the rebar size and spacing in the design that you have? With that information, it would be relatively easy to come up with an equivilant design.
DaveAtkins
