Modelling mill cutters in SolidWorks
I am having difficulting modelling a eccentric relief, helix angle 45°, ball nose, 3 flute in Solidworks. How do you model the teeth in Solidworks? Any help or suggestions would be appreciated.
RE: Modelling mill cutters in SolidWorks
That's a broad question.  Are you familiar with sweeping a profile or a cut along a helical path (check help files)?  You'll need to understand that fairly well, only with a ball end mill you'll want to edit the end of the helical path to curve under to the centerline.
How accurate does this need to be?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
