Capacitance Meter
Capacitance Meter
Im looking for a way to measure capacitance..in the pico farad range with at minimum .1pf precision..ive looked at using a 555 timer but found the precision to be greatly affected due to tempreture and interal drift inherent in the 555....
any suggestions would be greatly appreciated...the circuit must be of minimal power consumption and cost ..therefore looking for something that can be surface mounted
RE: Capacitance Meter
now what is your maximum range, you then deside on high quality crystal to do the job
the major problem would be the wire capacitances because it is in the range of few pf's, you need to compesate hor those too.
Pf range needs higher frequency than commercial product like 555 can provide
Maged A. Mohamed
http://magedm.freeyellow.com
http://www.magedsoft.com
Probably the only technique with enough sensitivity would be to connect the unknown capacitance to a high frequency LC oscillator circuit working up in the tens or hundreds of Mhz range, and note the change in oscillation frequency.
