Updating PDMWorks Vault with Task Sheduler
There is an option within SolidWorks Task scheduler to update all files within the PDMWorks vault to the current version (2005 sp1.1) of SolidWorks. Unfortunately, all I ever get is an exception error when I try to select the project to update or select the whole vault. This happens from both win2000 and XP machines. Any clues anyone. Thanks in advanced for any help.
RE: Updating PDMWorks Vault with Task Sheduler
I also have checked in small assemblies with around 10 or 20 parts in less than a minute, but i am talking about assemblies of around 200 - 300 parts, still not excessively large and these take a long while. The local working directory has only contained the files associated with this assembly and also has no sub directories.
Also, make sure everyone is not using PDMWorks when you update it.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
Ta.
If it's crashing try repairing SW. you can't just repair TS, because it's installed with SW.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
