Positioning an imported feature
Is it possible to reposition an imported feature relative to a previously created part in Solidworks? The standard postion is rotated 15 deg. from where I need it.
RE: Positioning an imported feature
Since it's imported anyhow, try the following...
  • Create a coordinate system that matches where you would like the part to be (use 2D and 3D sketches if/where needed)
  • Export the part to parasolid.  From the Save As dialog box, click Options, and select your new coordinate system as the CSYS of reference
  • reimport the parasolid (you can either create a new part or use "Insert→Feature→Imported")
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
SBaugh,
Quote:
Why not use the Move/Copy Command and move the body to the Origin. Seems easier to me, but that's just my Opinion.
I prefer TheTick's method too. The only advantage I know of is a cleaner looking Feature Tree.
Ken
If you want a cleaner tree, then use the Move/Copy command and export it out as a parasoild and back in and you get the same thing, with less clicks and less hassle.
Reards,
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
If the imported part is in an assembly file it's easy.
Just select the part.
Select the rotate command.
Set the block that says free drag to by delta xyz.
Then rotate it 15 degrees around the axis you wish to.
But, you called it a feature instead of a part, so maybe I'm missing something, and you're not doing what I think you are.
The reason I use the method I described is because it is easier when dealing with "in-car position" designs.  Always best for us when imported parts come in where expected without additional features.  Minimizes the possibility of accidental changes and/or stupid questions about why/how something is moved.
