Double click view box
I'm now using 2005 sp0. In 2004 I used to have handles to drag view size (bounding box)which are missing in 2005. Is it possible to change this anymore?
I just found by accident, that if you double click the bounding box of a view, the corners highlight. What does that do for you?
Thanks!
Thanks!
RE: Double click view box
To add a dim, balloon, etc in a view... active it by double-clicking on it. Double-click on it again to de-activate.
This is better than adding something to a dwg and SW picks the closest view to attach to.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
Helpful SW websites every user should be aware of. FAQ559-520
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. Thread559-116096
SW just made it easier to activate the view you want, then you can add whatever you want anywhere on the dwg and it will attach to that view.
Chris
ctopher's home site
Well, I guess it's a moot point now that SW05 has the double-click function ... that makes more sense.
Chris
ctopher's home site
