Mesh Refinement in Mechanica
Does anyone know how to seed additional points inside of a volume to increase the mesh density within a selective region of the model?
I know it is possible to modify the element creation limits, but this will yield an increased mesh density over the entire model.
I am able to seed the outer surfaces of the volume with points to increase the mesh density, but creating datum points on the inside of the volume seems to have no effect.
Any help would be appreciated.
Steve
Steve
RE: Mesh Refinement in Mechanica
Good Luck
Go Mechanical Engineering
Tobalcane
Best regards,
Matthew Ian Loew
GREAT TIP! It worked perfectly.
Steve
Glad it worked for you! Thanks for the follow-up. It is good to know when something works (or didn't).
Best regards,
Matthew Ian Loew
I guess I stand corrected. I just came from a ProM class and that was one of my questions and the instructor did what you suggested and it did not work for him. That scares me...
Tobalcane
