Water-Ethylene Glycol mixture properties
Dear friends,
Can somebody help me give references/ web pages to find the Water-Ethylene Glycol mixture properties with varying ratio ( 50:50, 75:25 etc)
KMPillai
RE: Water-Ethylene Glycol mixture properties
There are graphs in ASHRAE’s fundamentals handbook that show the data.
Dear Friends,
Thank you very much for your information.
KMPillai
  How does pressure affect the properties of glycol in it's full strength not in water solution? Let's say around 2000psig at 80 degrees F.
Here is another source of information on PG mixtures.
http://www.dynalene.com/pg.html  (from Texas73)
I’ve seen both PG & EG  at 1200 PSIG but if I remember there was a additive in them.  You might query the people at the above website.
There is even a chart on the label of some brands of antifreeze.  AF has additives for anticorrosion, which generally beneficial.  I found this link with useful tables:
http://www.raypak.com/afreeze.htm
