Kit-car Cycle Arch Brackets
Has anyone looked into the Cycle arch brakets on kit-cars. Which fail due to cyclic load due to being mounted directly on the hub.The cycle arch bracket vibrates or ossilates at the close to the natural frequency of the road.(300HZ)
The problem maybe solved by adding a simple bobbin between the bracket and the hub.
Rick
Rick
RE: Kit-car Cycle Arch Brackets
Pete.
