Define weld co-ordinate for weldrobot
hello ,
We want to weld a construction designed in SW with a weldrobot.
I did the following thing :
For example i want to weld a u profile on a sheet.
I convert the outline dimensions of the u-profile on the sheetsurface.
Whit a api i can define the begin and endpoint of the sketchlines in position of the origin.
Those co-ordinates can be used for the weldrobot.
Is there an other possibility to do this ? (software)
RE: Define weld co-ordinate for weldrobot
