Printing problems
Printing problems
Have run into a printing problem that I hope someone can help with. We received a set of drawings from a customer that they wanted us to finish dimensioning, and then use as a template to match their drafting standards. Our AcadLT 2000 is set to pull ctb files off of our network server, so they are all stored in the same place, and everyone uses the same ones. But when we go to print one of the drawings that they sent us, it defaults to their page setup and plotting; On the plot device tab, for ctb options, it only lists "none". Cannot find a way to get it to list our plotting flies. Is this a setting somewhere? I had assumed it was "plot with plot styles" on the plot settings tab, but that didn't do it.
RE: Printing problems
Hope this helps.
Oh, and by the way THANK YOU!
CONVERTPSTYLES was the ticket.
Did I say thank you?
