cast stainless steel magnetism / corrosion
We are having trouble with a cast austenitic stainless part (304) that experiences superficial red rust even when exposed to mild environments. Despite being 304, the part is slightly magnetic(?). The part is also passivated.
> Is it common for a cast austenitic stainless steel parts (ex:304) to have some slight magnetism? Is this an indication of improper chemistry?
> Is the corrosion performace of cast stainless improved by solution annealing? (Can the magnetism be decreased/eliminated by solution annealing?)
> Any suggestions for improving the corrosion resistance of the part,...
RE: cast stainless steel magnetism / corrosion
What is the exact thermal history of your 304 raw stock? Was it purchased to a specification? If it was cooled too slowly from the cystallized temperature through the 1500F to 800F temperature range, it will be sensitzed.
If it has been sensitized, yes solution annealing will de-sensitize it which restores the corrosion resistance. I think it will also demag it but don't recall. There are a number of S.S. experts on this forum and one or more will shortly reply on the magnetic aspect.
The chemistry of your parts may be one factor. Determine the composiotin and plat it on a modified Schiffler diagram. This will tell you what the equalibruim ferrite level is. With Ni being expensive your supplier may be shaving and giving you a higher FN. This can be offset by increasing the Mn or N.
Annealing is usually helpful in improving corrosion resistance. Heat to 1950F, hold for long enough for everything to get uniformly hot, and rapid cool. If you do this in air you will need to pickle the parts to remove the oxide and Cr depleated layer.
You may want to try pickling some parts as is. If the real problem is just in a surface layer this might remove it.
You also need to make sure that the passivation was the last operation. There should be no machining or even handling (other than packing) after.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Another fact to consider is that handling of the casting(s) may induce iron contamination of the stainless surface. This can occur during descaling if steel or cast iron grid is used and if this is not followed by a proper blasting with an iron-free non-metallic grid. Another source of contamination can be the steel or iron dust that's all over the place in foundries. This can be examined by a ferroxyl test.
Your description of the red rust on the surface points to my opinion more in this last direction.
