PC Mount Transformers
Is there a transformer manufacturer and/or Distributor in the US offering control transformers for pc card mounting, 380 volt primary, and with secondary voltages in the range of 12 to 24 volts, 4 to 10 VA or thereabout.
RE: PC Mount Transformers
"Venditori de oleum-vipera non vigere excordis populi"
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
voltage and power -- not to mention power consumption, dissipation, space etc.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
Nbucksa's idea is feasible as well. Probably should be at least considered if this is a production item. Design costs of an "electronic version" would quickly kill any cost benefit for low volumes.
Greetings Aksel
