hp 650c not printing all images
I am attempting to print detailed maps from ArcGIS/ArcMap to a hp650c plotter. When the maps come out, there are layers and objects missing. The print previews look fine, but what comes out of the plotter doesn't. This plotter has printed maps with this much detail before. Now, the readout says "Out of memory - Data was lost." I'm new to this, so I'm wondering if there is a way I can clear out the plotter's memory and start fresh. Or do I have to buy more memory for the plotter? Or is there some sort of loophole so I can get around this problem? Could it be a problem with the software? I'm at a loss, so any help at all would be greatly appreciated.
RE: hp 650c not printing all images
So this out of memory could be plotter( but you say it did plot similar maps ), or your hard disk needs some free space (if windows check virtual memory settings), or wrong configuation some where eiher in operating system or application, some applications sets up a table or array to handle some file information , when it is full it generate thie misleading error.
Maged A. Mohamed
http://magedm.freeyellow.com
http://www.magedsoft.com
Print/Properties/Custom Properties/Advanced Tab
Check the box Process Document ...In Computer.
this is how i have to plot large plant layouts and large pdf files.
