Leak Currents in a Generation Building
The AC leak current values on our generation instalation in ground connections ranged between 0.07 and 6 Amps. The resuts of these measurements indicate an alert.
The impedance of the global grounding system is 0.34Ohm.
Witch are the safe current range in a generation building?
