Vessel & Equipment Lay Up Procedure
I need help with a simple equipment & vessel lay up procedure. Does anyone know where to find something like that?
J. Alton Cox
www.delucatest.com
RE: Vessel & Equipment Lay Up Procedure
In general the rule is 'clean and dry'. In some cases this just means draining things. In most it requires chemical cleaning and then using either desicants or dry nitrogen in order to protect all of the surfaces.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
http:/
