3DSMax to Solidworks
I've designed a blaster in 3DSMax for a laser tag arena.. We want to get a rapid prototype of it to check for real-world scale and fitting of circuits and components.. However, once exported, I can't seem to do anything with it at all in Solidworks.. Admittedly, I am a MAX fellow, and know nothing of Solidworks.. Right now, all I want to do is get a measurement of the model.. I can't figure out how to do it.. Is the STL format locked?
Is there someone available who could look at the file?
-Matthew
-Matthew
RE: 3DSMax to Solidworks
Depending on the size of our arena maybe a problem too. SW only has a certain size that SW will handle, anything outside of that is not valid and probably not translate over.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
I do have some problem areas I'm still ironing out (I booleaned a cylinder and have to rebuild some faces).. I'm not sure if it's a solid or surface, MAX only deals in tris and quads..
Size may be a problem.. MAX units are generic and mean nothing, they are just for reference (MAX is definitely not a CAD package).. I was hoping to scale it as needed in Solidworks, but I can't seem to do anything but rotate it..
Worse case senerio, can I build surfaces in Solidworks based off of MAX data?
-Matthew
If you can get a dimension, you can scale it. Try to go from point to point. (I didn't know SW could import an STL file.)
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
However, the Rapid Protyper we are going to use only takes STL format, so I'll be exporting to STL one way or the other..
Does this mean I can't get any measurements at all in Solidworks? Doesn't look that way.. I could scale it in MAX if I just knew how big the dang thing is..
We've also experimented with exporting to DXF and DWG, but neither imported correctly.. My point cloud was 2D, not 3D..
-Matthew
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
perhaps you should make a CNC model. This only needs the surface model. Sorry not to provide the answer you were looking for
