Given someone else's work...
I was given another engineer's work cause he wasn't getting it done. This is in addition to my own work. He wasn't fired and now doesn't have much responsibility. He sits there and reads the paper while I work. He's been around a lot longer than myself, is one title above myself, and probably makes $20,000 more than me a year. I'm by far the youngest in the department and I get results.
Should I ask for a larger (8% or greater) raise?
Should I request to be promoted to the same title?
Am I being taken advantage of?
RE: Given someone else's work...
Quite what the outcome would be I am not sure.
On the other hand - do you have time to do all that you are asked in a normal week? ie without working unpaid overtime?
Why not ask him to give you a hand on some of this stuff?
Cheers
Greg Locock
I don't work many extra hours because I'm not paid for it. If I was, I would.
He does help out but that's not the point.
www.SlideRuleEra.net
I would like a promotion but then I'd have the same title as others in the department that could be my dad and I don't think it would go over too well.
Cheers
Greg Locock
I have never ever asked for a raise throughout my 14 + years of working life. I felt I was always recognised for my work and paid accordingly, except on a couple of occasions when it probably got delayed for whatever reasons. Once I felt I was being taken for a ride, and my superiors were just using me and not worried about my growth, I quit that company.
The above may or may not apply in your case.
HVAC68
As told to me by my friend, a corporate HR type...
The kicker is that your colleague knows exactly what he's doing! The boss likely knows and tolerates it for whatever lame dysfunctional reason.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Be aware that when you take on extra work, if it means that it could mean that you are not performing to the best of your ability in any area.
There is a danger here that the engineer who sits and reads his paper can show that what he does do, gets done. You are only able to show lots of incomplete work despite working all the time.
There are only so many hours in the day. You may need to negotiate what work is to be done.
When given a new task, get it clearly defined and ask for your work to be prioritised and make good estimates of time involved.
Also, don't consider it "extra work" but new work.
There is a difference. If you are given new work with other work still in progress, you need to make it clear that you can only do so much and cannot complete other tasks.
Ask your boss what his priorities are and what work you should drop. You need him to be aware of the impact of adding new work to your workload.
You need to make your time management problems your boss's so that he fully understands what happens and why.
The alternative is that without understanding why you don't finish anything, they will think you are a poor worker, not a good one.
Don' try to do too much and don't let anyone try to make you do too much. Don't be obstructive, just share the problem of time management with your boss. After all, he has to be responsible for timely completion of tasks. He may not recognise this as a resource problem and he may end up thinking you are the one who is not capable of doing the work.
You know, there is a message here, and you have outlined it clearly, the guy who reads a paper is less stressed, completes his work and gets paid more and is more senior. YOU may be the one who is subsidising his life style! and taking the risks.
JMW
www.ViscoAnalyser.com
Put in the extra effort...show you're worth the extra bucks. If they don't come through, go elsewhere, but don't whine about conditions if you're not willing to put in the effort to progress yourself.
1. Look at the work that is given. is it something that you think will increase your skill and mechanical skill..hence..make your resume good. If yes, then just do it as best you can.
2. Look at it as a chance to impress your boss.
3. When you are the youngest one around, it is very tough environment.
Tell your boss to prioritize your task. This is very important. keep him updated everyweek. and remember, when you are ready to do those 3 things you mentioned, is your "bargaining power" high enough. If itsn't it will be a boomerang for you.
I did this for 3 years, getting bullied around, do all the leg work, and all that. It was mentally tough, but I manage to suck it up an I ended up learning so many things. When the layoff season comes around, I was one of the 3 MEs who survived out of 16...U know why, because I was cheaper and more productive than those guys.
I think the key is to keep your boss(es) updated on what you are doing.
Cheers.
APH
He is reading the paper with no responsibilities.
He wasn't fired.
YET!!!
It normally takes a while for a department manager and HR to "build a file" on someone prior to firing. Reading the paper while you do work that he couldn't handle are two points that go into that file.
Do your job and let the system work through the deal.
John
Hg
He could have those legendary pictures of someone with a goat.
A good reason never to drink at company picnic.
Your attitude of "I don't work many extra hours because I'm not paid for it. If I was, I would", is exactly why you aren't paid for it. Management are sometimes not the idiots you consider them to be. They probably see more than you realize and now is the time for you to "step up to the plate" if you want to be recognized.
1. You can be taken adavantage by willing working long hours. Your boss will fill you with more work, thinking that you are OK to work long hours.
2. In my experience, 8-9 hours/day is enough to make my eyes really sore at the end of the day. detail attention is reduced, you can make more mistake that way. Your brain is exhausted after that.
3. If you are tired after work, you can't do anything else outside work, unless you have no life outside work.
If your boss gave you someone's els work ,while others are chilling, then I'm pretty sure that he can't manage his engineer, and he will continue to shuffle work to you as long as he can.
I think the goal should be 40 Hrs average. Your paid for your knowledge not your time. You want to get paid by the hour become a teamster or an electrican.
50 hrs some weeks 32 hrs sometime in the summer. Even on those 32 hr weeks don't most of us still think about work? Do you ever solve problems somewhere besides your desk or your cube?
In the "you can't win" department--you can work long hours to show how dedicated you are, and then they might say that you must not be managing your time well if you need to stay so late.
Hg
We are speaking about working hours, if 40 is too much, if 50 is Ok. We are engineers. We care about outputs, productivity. I can give you my example:
I was used to work around 11-12h/day. Then, last year I enrolled in a MBA in a post-labour schedule, and I was "forced" to reduce my working time. Now I work an average of 9.5 hours/day. A 20% decrease on the working time.
Did my work suffered with it?
I cannot say that it didn't, specially in the first times while I was organizing myself to the new schedule. After that, I don't think that it is so noticeable the impact. In fact, I even think that I've improved my productivity, since I think that I can make maybe 95% of the work that I did previously:
-I delegate much more;
-I don't count on "Well, in the end of the day when everybody's gone I will finish this";
-I organize my work better.
So working hours doesn't mean anything. What means is what comes out of those hours. Of course that is not the point of view of most of the bosses. For them, you could even bring your bed and stay in the office.
What I don't understand is the concept of "open-ended" work. Is there no deadlines? Are they constantly overrun?
Idf yes, then your work is not open ended. You are making it open-ended. That's different.
Sorry for the long post.
PR
Sure, I thought about work from the day I wake up to the day I'm about to go to bed. I agree with all of you about what comes out of those hours. What I'm saying is that, at some point, you have to be able to say NO to your boss. I have experienced that I work 60 hours/week for almost 4 months for most days of the week, and it got me bad. And it happened like that because I can't say no to my boss, worrying what he's thinking about me, so he kept shufflying work to me while he gots the credit. Now, it it my boss fault, NO, it's mine because I can't convince him that this situation will not benefit both me and company in the long term. Even when I was sick at home one time, he called me to give direction to others on how to solve the problem. After 4 years, I quit and find a new job.
This is only my 2 cent.
APH
Engineers are professionals; however, that does not mean that we should be expected to donate our valuable time on a consistent basis.
Thane
Hg
APH
2. Enjoy your work. You won't feel the hours passing by. It's great to do what you enjoy and yet get paid for it.
3. If you are not enjoying your work - change your job or find ways and means of making your work enjoyable.
HVAC68
If you are learning, keep learning and it will pay off at this job or the next. Perhaps as you learn to your tasks completed better your boss will realize that he does not need to keep the other guy around, that still leaves you where you are at. My point is if they fire the other guy you may still gain nothing except even more work.
If you are gaining knowledge you will be rewarded eventually. As I stated earlier, I began my career as a Machinist, actually just running a saw cutting stock for the lathes. 17 years later I have worked my through CNC Programming, Production Management, R&D Management, Project management, Product Design... Here I am today working in Engineering (without a college degree) I have hands on experience with all aspects of manufacturing (welding, programming, laser machining, quality control, design, analysis...) and I am not the highest paid person in my department. I get up every day and go to work with a smile, do the best I can do, learn as much as I can learn and come home feeling pretty good about myself. 17 years ago I was running a cut off saw in a third rate rats nest of a machine shop making $5.00 an hour, but by taking on everything thrown my way, showing a will to learn, making the effort to learn and achieve, in return I have been rewarded with a good career that many machinists could only dream of. I have had the fortunate opportunity to work some large companies on some very large projects, and I love it. Life is long, look at the big picture, appreciate where your life could be heading.
I gather from the posts that many of you work 40 hours per week for a salary in a clearly defined position where you perhaps do not get opportunities to show individuality, initiative and self-motivation, or at least it appears to be unrecognized when you do. To remedy that requires communication with your supervisors/mentors.
The engineering profession is clearly divided into two factions of practice...licensed practice and non-licensed practice. For those who have engineering degrees but choose to practice in a non-licensed capacity, be aware that this aspect of the profession is heading toward hourly pay scales, non-professional status, and in some cases unionization. All are sad days for the engineering profession.
How would you feel if you physician said "OK, it's 5:00. Time to go home. We'll finish this heart transplant in the morning."? No, engineering is not often "life and death", but it has an importance in society that is often forgotten by the public and even by those of us in the profession. We provide important functions for the betterment of life and the public. We are charged (as licensed professionals) with the protection of the health, safety, and welfare of the public at large in our practice of engineering. That charge is a significant responsibility, for which we should be proud and for which we should be appropriately compensated. If we continue to act like hourly employees on a loading dock, we'll be treated accordingly.
Keep the standards high and meet them. It is the only way our profession survives.
" For those who have engineering degrees but choose to practice in a non-licensed capacity, be aware that this aspect of the profession is heading toward hourly pay scales, non-professional status, and in some cases unionization. All are sad days for the engineering profession."
Have you any objective evidence that this trend is the case, across the profession as a whole? Increasing unionisation seems a tad unlikely given the general trend (not that it is a bad thing, and don't kid yourself that a professional association is anything other than a union, the best union I know of is the AMA).
By the way I am non licensed and 25% of my job IS life and death, for those of you who persist in buying SUVs and won't wear seatbelts.
Cheers
Greg Locock
If you feel you are being victimized, look for another job...be careful to not do anything to sully your reputation where you are working now. I had a worse experience in a field office; just myself and my manager. My manager did very little real work, mostly surfed porn on the internet. He embezzled, cheated on his expense account, etc....when I proved this to management, they gave him a slap on the wrist. He was forced to pay back only a small amount of the money he had embezzled. Typical office politics. Rather than let this eat me alive with bad emotions, I felt a lot better to quit, with one week's notice.
The license exempt engineers that you claim are "nonprofessional" send us rolling down the road in cars, get us flying around in airplanes, design the ordnance that defends our nation & world and put men on the moon. I am continually amazed at the innovative products that are continuously being created by license exempt engineers in industry. I've worked in both industry and consulting. The licensed engineers that I've met in consulting are no more "professional" than the license exempt engineers that I've met in industry.
nodiggity,
I'd give them a year or two and see if they properly reward you for your efforts. If they do, stay where you are. If they don't, then find another employer who does reward good work.
