Does anyone knows how to draw CAMS in Solidworks 2004?
Gentleman:
Does anyone knows of a good tutorial a WebLink or a PDF file that will allow me to learn how to draw CAMS in Solidworks 2004?
Does Solidworks 2004 have a tool that will facilitate drawing this type trajectories?
I will appreciate your help on this.
Andy
Andy
RE: Does anyone knows how to draw CAMS in Solidworks 2004?
Several options come to mind: Do you have Toolbox in your 2004? Does it have the Cam options? You might try that. I was given a cam over 36" in diameter but it had multiple points on XY coordinates and I merely connected them using a spline. Not sure if this helps but I'm sure there are others out here that can take this a lot further is needed.
Dennis
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
