measurement & control
1) Is it possible to calibrate a dp transmitter in workshop below its minimum span limit. We purchased a transmitter range LRL = -10kpa and URL 10 kpa. Minimum span limit given on Tr was 5 kpa. We adjusted it to 2.5 kpa ( forgotten span limit) by applying pressure on + leg and leaving -leg in area. But when installed in field it started giving random values. Why ?
2) How I can calculate minimum plate thickness for flow element ?
3) Is someone help me to calculate dp for elbow type flow measurement?
RE: measurement & control
