Strange Characters messes mathcad equations
From some reason when I key mathcad operators such as the colon-equal (:=) or just the equal sign, etc. I see pictures such as disk pictures instead of the :=. I assume it is probably happened due to an installation of a new program that changed files in the Windows 2000 professional system.
Does anyone had the same problem and if so is there a way to correct it without reinstalling Windows 2000 Pro?
RE: Strange Characters messes mathcad equations
TTFN
Cheers
Greg Locock
This won't help, but I had some issues with copying/pasting in Mathcad 2000 under XP which were supposed to be fixed under the latest patch. Later found out that they knew about the problem of copy/paste but "were no longer supporting Mathcad 2000 under XP". In the end I managed to reduce the problem by switching off my anti-virus.
Best of luck,
-- drej --
Bung
Life is non-linear...
