Shock Response Spectrum (SRS) in Matlab
Here is an SRS code in Matlab.  I have more of these types of programs for shock and vibration, so please let me know if there is an interest.
Tom Irvine
disp(' ')
disp(' srs.m   ver 1.4   January 31, 2005')
disp(' by Tom Irvine   Email: tomirvine@aol.com')
disp(' ')
disp(' This program calculates the shock response spectrum')
disp(' of an acceleration time history, which is pre-loaded into Matlab.')
disp(' The time history must have two columns: time(sec) & acceleration')
disp(' ')
clear t;
clear y;
clear yy;
clear n;
clear fn;
clear a1;
clear a2
clear b1;
clear b2;
clear jnum;
clear THM;
clear resp;
clear x_pos;
clear x_neg;
iunit=input(' Enter acceleration unit:   1= G   2= m/sec^2  ');
disp(' ')
disp(' Select file input method ');
disp('   1=external ASCII file ');
disp('   2=file preloaded into Matlab ');
file_choice = input(');
if(file_choice==1)
    disp(' Enter the input filename ');
    filename = input(' ','s');
    fid = fopen(filename,'r');
    THM = fscanf(fid,'%g %g',[2 inf]);
    THM=THM';
else
    THM = input(' Enter the matrix name:  ');
end
t=THM(:,1);
y=THM(:,2);
tmx=max(t);
tmi=min(t);
n = length(y);
out1 = sprintf('\n  %d samples \n',n);
disp(out1)
dt=(tmx-tmi)/(n-1);
sr=1./dt;
out1 = sprintf(' SR  = %g samples/sec    dt = %g sec \n',sr,dt);
disp(out1)
fn(1)=input(' Enter the starting frequency (Hz)  ');
if fn(1)>sr/30.
    fn(1)=sr/30.;
end
idamp=input(' Enter damping format:  1= damping ratio   2= Q  ');
disp(' ')
if(idamp==1)
    damp=input(' Enter damping ratio (typically 0.05) ');
else
    Q=input(' Enter the amplification factor (typically Q=10) ');
    damp=1./(2.*Q);
end
tmax=(tmx-tmi) + 1./fn(1);
limit = round( tmax/dt );
n=limit;
yy=zeros(1,limit);
for i=1:length(y)
        yy(i)=y(i);
end
disp(' ')
disp(' Calculating response..... ')
%  SRS engine
for j=1:1000
    omega=2.*pi*fn(j);
    omegad=omega*sqrt(1.-(damp^2));
    cosd=cos(omegad*dt);
    sind=sin(omegad*dt);
    domegadt=damp*omega*dt;
    a1(j)=2.*exp(-domegadt)*cosd;
    a2(j)=-exp(-2.*domegadt);
    b1(j)=2.*domegadt;
    b2(j)=omega*dt*exp(-domegadt);
    b2(j)=b2(j)*( (omega/omegad)*(1.-2.*(damp^2))*sind -2.*damp*cosd );
    forward=[ b1(j),  b2(j),      0 ];
    back   =[     1, -a1(j), -a2(j) ];
    resp=filter(forward,back,yy);
    x_pos(j)= max(resp);
    x_neg(j)= min(resp);
    jnum=j;
    if  fn(j) > sr/8.
        break
    end
    fn(j+1)=fn(1)*(2. ^ (j*(1./12.)));
end
%  Output options
disp(' ')
disp(' Select output option ');
choice=input(' 1=plot only   2=plot & output text file  ' );
disp(' ')
if choice == 2
   disp(' Enter output filename ');
   SRS_filename = input(' ','s');
   fid = fopen(SRS_filename,'w');
   for j=1:jnum
        fprintf(fid,'%7.2f %10.3f %10.3f \n',fn(j),x_pos(j),abs(x_neg(j)));
   end
   fclose(fid);
end
%  Plot SRS
disp(' ')
disp(' Plotting output..... ')
%  Find limits for plot
srs_max = max(x_pos);
if max( abs(x_neg) ) > srs_max
    srs_max = max( abs(x_neg ));
end
srs_min = min(x_pos);
if min( abs(x_neg) ) < srs_min
    srs_min = min( abs(x_neg ));
end
figure(1);
plot(fn,x_pos,fn,abs(x_neg),'-.');
if iunit==1
    ylabel('Peak Accel (G)');
else
    ylabel('Peak Accel (m/sec^2)');
end
xlabel('Natural Frequency (Hz)');
Q=1./(2.*damp);
out5 = sprintf(' Acceleration Shock Response Spectrum Q=%g ',Q);
title(out5);
grid;
set(gca,'MinorGridLineStyle','none','GridLineStyle',':','XScale','log','YScale','log');
legend ('positive','negative',2);
ymax= 10^(round(log10(srs_max)+0.8));
ymin= 10^(round(log10(srs_min)-0.6));
fmax=max(fn);
fmin=fmax/10.;
fmax= 10^(round(log10(fmax)+0.5));
if  fn(1) >= 0.1
    fmin=0.1;
end
if  fn(1) >= 1
    fmin=1;
end
if  fn(1) >= 10
    fmin=10;
end
if  fn(1) >= 100
    fmin=100;
end
axis([fmin,fmax,ymin,ymax]);
disp(' ')
disp(' Plot pseudo velocity? ');
vchoice=input(' 1=yes   2=no  ' );
if(vchoice==1)
figure(2);
%   Convert to pseudo velocity
for j=1:jnum
    if iunit==1
       x_pos(j)=386.*x_pos(j)/(2.*pi*fn(j));
       x_neg(j)=386.*x_neg(j)/(2.*pi*fn(j));
    else
       x_pos(j)=x_pos(j)/(2.*pi*fn(j));
       x_neg(j)=x_neg(j)/(2.*pi*fn(j));
    end
end
end
end
if iunit==1
    ylabel('Velocity (in/sec)');
else
    ylabel('Velocity (m/sec)');
end
Q=1./(2.*damp);
out5 = sprintf(' Pseudo Velocity Shock Response Spectrum Q=%g ',Q);
title(out5);
grid;
end
RE: Shock Response Spectrum (SRS) in Matlab
I don't understand. What is your question?
M
Dr Michael F Platten
Tom didn't have question, he was essentially posting the answer to a FAQ, which is probably where it should go.
TTFN
