Snap-fit drawn steel enclosure?
I know this is not the right forum for this but I didn't know where else to go. Delete if inappropriate.
We do a lot of work with small (2"x2") deep-drawn steel enclosures. We're looking for a supplier who provides some kind of snap fit sealing method for same. I can find tons of deep-draw sources but see nobody offering a snap fit function. Probably because there's no-such-thing. Anybody have a place I can look? Or a more appropriate place to post?
RE: Snap-fit drawn steel enclosure?
What is a snap fit sealing method/function? Can you describe it?
We use similar square enclosures and we currently 'slipfit' a shallow drawn cover over the open end of them and then solder-seal. On some non-hermetic units, we would like to install a cover over them and have it be secure without having to solder. We have some 'custom' ideas for solving this but had hoped that there was something standard out there.
Thanks for the reply.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Cookie tin?
Small grease retaining hub cap on pre-90s RWD car?
A formed lip is always involved. Might be easier to form a 3rd piece with Z section
