ballscrew anti-rotation device
I am looking for the ideas of anti-rotation features for linear actuators driven by electric motor and ballscrew. There are some ideas I have come across such as make the actuator shaft non-circular shape which will increase the machining cost and make the sealing more difficult also there is ballsplin shaft can be used to mounted to a ballscrew. If you have more ideas, please share. Thanks in advance.
RE: ballscrew anti-rotation device
Are you sure you posted to the right category? What do linear actuators have to do with electronic packaging?
Tunalover
