Single rib feature
Single rib feature
How to create? I have seen part, where it's used, but what tool does that? Rib?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Single rib feature
What type of rib, for what?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
Then you can reference it in a post here using their "Direct link to image" path, which would be something like:-
[img http://img235.exs.cx/img235/4310/bigsmiley9za.gif]
You will have to create the bend stiffening rib using regular SW features (not sheet metal). Take note though, that the sheet metal "flatten" function will not flatten the ribs.
In this case, you could use a sweep to create what you need.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
