Another Assembly Question
I am wondering how you mate an o-ring to an o-ring grove so that when you ove the part the o-ring goes with it?
the version of unigraphcs that I am using is UG NX 2
RE: Another Assembly Question
Jonathan T. Schmidt
http://www.schmidtmotorworks.com
It just so happens that I have been doing the exact same thing recently.
You will need to have a datum plane running perpendicular through the o-ring. I use this to create an offset from the bottom of the o-ring groove, or other appropriate reference as required, to the datum plane at half the o-ring thickness.
Also you should have an axis to allow you to align you o-ring to the o-ring groove, assuming it to be circular.
If for some unusual situation you have an o-ring which is to fit into a irregular or non-circular groove, three datums would you best option possibly.
I hope this is of help
Best Regards
Dave
You then don't need to have a positional expression for 1/2 the o-ring groove.
Guess this would depend on the appliction a bit though.
Hope that's useful.
Mark Benson
CAD Support Engineer
