Can a Datum feature reference itself in Y14.5M (GD&T)?
If I have a part with 3 datums, datum A is the surface on which I have datum B - a hole and datum C - the width of a slot and I want to tolerance the length of the slot can I use a positional tolerance that references A|B|C or can I only use A|B because the slot is C?
If I do tolerance the length to A|B|C what would that physically mean?  How could the length of the slot vary, positionally, with respect to the width of the slot?
J
(Originally posted in ANSI standards forum)
RE: Can a Datum feature reference itself in Y14.5M (GD&T)?
jmarkus,
   Your datum C controls the rotation of your part.  Until this is controlled, there is no rotational datum.  Your slot's width is controlled by Datums_A and_B.  Once the slot is in place, you have three datums.
   If there was a feature you could use to control your slot, *it* would be datum_C, wouldn't it?  :)
                          JHG
The rotation is controlled by the width of the slot, so datum C is only the width.  The question is the length is controlled back to A & B, but can it be controlled back to C when C is a different dimension on the same feature?
J
We do this.  This is effectively breaking the slot into two features, length and width.
Imagine if you were dimensioning a different slot.  You could give each dimension (width and length) its own positional tolerance.  No difference.  Completely legal, just not common.  Don't forget to omit diamter symbol.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
You can't orient to something which does not already exist. That is simple rule to remember since this principle must be consistant for everyone involved in the process. The machinist would be unable to align to that coordinate system.
Slots which mate with a floating or fixed fastener are handled in special way and you should be aware of this method. It's called a 'Boundary' condition (pg 143) which just takes into allowance the special shape and possibly different tolerances to define the feature's virtual condition. If the function of the width of the slot is a mating or aligning and the next important feature then it MUST be chosen as a datum to locate other features that are connected in someway so as to imply their intended purpose too.
But physically, how could the length of the slot vary, positionally, with respect to the width of the slot?  To me this seems impossible and therefore dimensioning the length of the slot to the width is meaningless.  So if I position the length of the slot to |A|B| only, am I missing something?
Because the boundary callout pins the virtual condition boundary. The virtual condition boundary ensures the worst case fit of the mating part is line on line contact only unless you want an interference. Makes perfect sense that the shape of the tolerance zone of a slot type feature NEEDS to be rectangular. Tolerancing system must be able to accomodate the needs of building real parts in an concise way subject to only one interpretation or it's rendered useless.
Quote (jmarkus):
Picture that the slot position is constrained along the slot centerline (the line symmetrical between the two linear portions).  The entire slot can "slide" along that line until it is constrained by another dimension and tolerance.
Orientation by definition is directing towards a point.  My question is: Can a line or plane be 'oriented' with respect to another plane?  Just something to ponder.
This with regards to plane C as the orienting feature.
