INTERNAL ERROR problem !!
I have been getting this message quite oftenly while trying to open my autocad 2004 drawing file "INTERNAL ERROR: !dbqspace.h@410: epPermanentlyErased". Other times, I get this one " INTERNAL ERROR:  !dblayoti.cpp@97: ePermanentlyErased". This also seems to affect the BAK file as well.
what does this means? I've tried to recover to same file and then bang! another error "FATAL ERROR:Unhandled Access Violation Reading 0x0004 Exception at 454a25h" What can I
do to recover that file or troubleshoot the problem? I just want to know also if anyone else has experienced the same.
RE: INTERNAL ERROR problem !!
Thanks borgunit for the link. I dont seem to have installed the said utilities. Hence the prob may be more than that.I will still check out for more hints...
