Supplier of continuous 220m lenght of hose
Does anyone know where I could buy a continuous 220m length of industrial grade hose. The hose will supply water at a pressure of 5 to 20 bar at a flow rate of around 1-2 litres per second and be around 25mm diameter. It is for a mine and will be wound on a winch drum and will be required to support it's own (+water) weight when it is unrolled 200 metres down a verticle shaft.
RE: Supplier of continuous 220m lenght of hose
