Vacuum Pick & Place in Dusty Environment
Did a search in a few forums but came up empty handed.
Using a Festo vacuum module (13 CFM) (with its own blowoff system, and internal solenoid valves) in a very dusty environment. Even using a 40, 50 and recently 10 micron inline air filters, the vacuum modules are still malfunctioning, due to the dust. Very delicate internal parts.
Next, tried a simple always-on vacuum venturi unit (25 CFM), but the same happened; dust clogging the nozzles and vacuum drops.
Cannot use any other type of pick and place (grippers), because I'm picking up a 5-10 gram flat square pad.
The dust is corn starch, and can't get rid of it (must stay on food product).
Anyone with any information, I appreciate it. What about a Venturi nozzle, larger than the size of the dust particles that would simply exhaust the dust? Can't find any.
Thanks.
Thanks.
RE: Vacuum Pick & Place in Dusty Environment
A couple of vendors to look at (there are MANY more):
Schmalz
PIAB
TygerDawg
If the Venturi were 1/8" opening or larger, then I wouldn't have a problem (?), but large CFM, which is OK.
Checked out PIAM and Schmalz; look like European.
Any other hints?
Because of the dust issue, you're probably going to have to get creative about blowing out the dust every few cycles in a clean-off step. This can be done by piping in a solenoid valve to control clean-off through the suction tube, or put in a separate external station for clean-off.
TygerDawg
Some things I have done in dusty applications is to put a jar type filter between the cup and pump and not turn on the pump until on the part. The not turning the pump on until on the part really helps if you have a fairly non-porous part.
Another thing if you go with the big venturi is too make your own muffler using brillo pads in a pvc pipe. Get a 4" pipe about 6" long and put the pads inside. Cap both ends then run the air in on end and drill a bunch of holes in other end. These really silence well and are about impossible to clog.
Barry1961
the Suction was turned into a blowing applacation that ran all the time, untill it was time to reverse the action and vacumum up the part.
The outgoing air flow cleaned the surface, the incomming vacumum picked up the part.
Good solution, zjBull.
