how to make a tube from a strip?
Hi there,
Is there the possibility in SolidWorks to transform a strip into a tube?
e.g. i have a stip which has the width = 40mm and thickness=2mm. I would like to see the edges of the strip when it will get a round shape lets say around 270degree
RE: how to make a tube from a strip?
Start with the curve. You can dim the length as an arclength - in dim select the curve, then each endpoint. Then use sheetmetal Base-Flange. You will then be able to flatten and get the strip
