Westinghouse CO-8 curve information
I am trying to find the equation used to calculate the time current characteristic curve for a Westinghouse CO-8 induction disk relay.  I have the curves originally published by Westinghouse but i need to enter information into coordination software for a point in between time dials.  So if someone has the equation or can point me in the right direction i would appreciate it.
RE: Westinghouse CO-8 curve information
Your software should really incorporate a curve-fitting routine that will allow you to enter curves via a listing of points.  There will be a lot of curves that will not have a published mathematical expression.
Most commercial coordination software provides this capability.
