Configurations-Design Tables with Tolerance
I have a bearing design with 2 configurations. The only difference is the ID has a different size and tolerance. What I'd like to know is how display the tolerance in design table and to display the tolerance with different values for the same dimension.
I have the dimension set for "This Configuration Only" for both configurations and successful in creating a design table. The only help I need is with the tolerance to show up in the design table, and to have different tolerance values for that dimension. I hope I'm clear with my question.
Macduff
Meggitt Airdynamics Inc.
Dell Precision 370
SW2004 Pro SP4.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
RE: Configurations-Design Tables with Tolerance
I don't believe dimension tolerances can be driven from a DT.
Time for an Enhancement Request?
& all the best.
You can drive the tolerance from a DT in 2005
I believe it was not untill 2005 that you could even set up differant tolerance for a dim based on configuration.
Thanks for your help fellas.
Best,
Macduff
Dell Precision 370
SW2004 Pro SP4.1
XP Pro SP2.0
