Fire resistance of construction steel
Dear Colleagues:
Can anyone advice if there is a special type of Steel that I can specify to comply with special Fire Ratings. In fact how can I comply with a Passive Fire rating of 15 min or 30 min or even 60 minutes.
can I simply comply changing the type of steel or by specifying greater sections.
RE: Fire resistance of construction steel
Fire proofing is applied to the surface of structural steel to comply with Fire Rating classifications.
