WN Flange weld shrinkage rotates my SS flange
What is BEST PRACTICE for welding a 60" Dia SS WN flange to keep the weld from shrinking & rotating the flange face 1/8" at OD. The flange lays back at OD when weld shrinks.
Thank you
Dee Anderson
Thank you
Dee Anderson
RE: WN Flange weld shrinkage rotates my SS flange
ID bevels on Flange & Pipe with 1/6" lands.
1. Tig root ID
2. Flux core ID 1 pass
3. Sub Arc ID
4. BAck gouge OD & Sub ARc 1 pass
The flange face was flat until step 4 where it pulled 1/8" towards the weld the flange OD.
We had 1/8" lands at first and it pulled worse.
We tried 200F preheat but it was no help.
Thank you,
Dee Anderson
Dee
