Moving Objects
Moving Objects
I am not sure if this question has been answered before, and if it was sorry for the repeat. I use Autodesk Land Desktop and I move objects around quite a bit. Nothing annoys me more than when the object I am moving jumps an inch down and to the left the first time i move the object. So then I have to select it and move it to where I really want it. Why does it do this and is there any way to fix it? Thanks!
RE: Moving Objects
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: Moving Objects
You've probably got "Running Object Snap" selected. This specifies that running object snaps override coordinate entry at all times. Or under the OSNAPCOORD command, 0 is selected.
Select "Keyboard Entry " instead. This specifies that coordinate entry overrides running object snaps at all times. You can also select this option by setting OSNAPCOORD to 1.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
RE: Moving Objects
Before:
text
text text text
text text
After:
text
text text text
text text
Anyway, I am sorry if "text" is not considered and "object". I realize now that the title may have been a bit misleading. I'm a noob at this still. Thanks for all your help!!
RE: Moving Objects
RE: Moving Objects
RE: Moving Objects
RE: Moving Objects
