Auto relief in sheet metal
I am creating a sheetmetal part in Solidworks 2005. I start with a base/flange piece which looks like a segmented "J". I go to add a edge flange from one of the segments with the flange position set at "material outside". Is there a setting that I need to turn on to get a relief at the corner or am I going about this wrong.
Thanks.
Thanks.
RE: Auto relief in sheet metal
Try changing to "material inside" to see if you get a relief.
