steel for injection molding machines
3
hello friends,
I have one problem so i would like to ask you something.
I'm searching a steel to be used for injection molding machines.
Here the specs:
Form:  bar  max 45 mm diam.
It has to be resisting at impact of hot material 800°C (today we have to use a coating of the die).
This temperature is reached only at the moment of injection, not permanently.......
Hardness of coating 1200 vickers.
Must have good resilience too.
Today we must use a coating.  However we want to use only a steel without coating....
Do you have a designation to suggest ?
..or any additional help..
Thank you very much
RE: steel for injection molding machines
I presume that you are molding plastics, with fillers.
I don't know how close you can get, but call Crucible.
The CPM grades have some great properties, CPM 15V is about as hard as a tool steel can get.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
What is the material you're injecting?  Is this a metal (die casting) injection molding machine, or polymers?  Check out the link:
http://www.crucibleservice.com/eselector/index.html
There'll surely be something there you can use, but depending on the specifics of your application, a coating may still be necessary.
