getting values after running a macro
I am trying to run and macro within a macro. Say main macro is -- macro_main and the internal macro -- macro_sub
I am passing a variable (ux) from macro_main to macro_sub as macro_sub,ux
Now, I am doing some computations inside macro_sub and would like to retain the modified value of ux in macro_sub once it returns to macro_main.
Kindly do tell me method how I can do it??
Ansys by default reverts back to original value after it excutes macro_sub and comes to macro_main. I would like to write a macro something like the *get or *set commands. is this possible?? I want to know if yes, can I increase it to more than one variable??
In short is there a concept of pass by 'pass by address' rather than 'pass by value'?? (in terms of progamming jargon c++ or Java). do remember that I cannot write 'ux' inside macro_sub as its a very generalised macro - like a function.
Only solution I can think of as of now ...
save the parameter in a file using parsav and read using parres?? any pointers will be highly appreciated.
RE: getting values after running a macro
