Water reservoir design actions
I am in the stages of designing a water reservoir. With static backfill pressures how do I find the vertical, horizontal bending moments and shears in the concrete wall?The reservoir is not being stressed. The wall in effect will act as a retaining wall and will be full fixed into the foundation. Is there any literature which will help me find the actions in the wall when I know the pressures in the wall. Even something that would tell me the percentage of load converted to membrane shear and bending moment.
Any help would be appreciated
RE: Water reservoir design actions
The last reprint that I have, is July 1970, so it may now be out of print.
It has 5 different plate edge conditions (such as fixed on three sides & free on top), with 11 different loading cases. These vary from uniform load for full height, 2/3 height, 1/3 height, various combinations of water loading etc.
Each plate has an 'a' dimension of half width, & a 'b' dimansion of full height. The plates have vertical & horizontal moments & reactions for a/b configurations from 1/8 to 3/2.
