A615 Gr60 Rebar -- Low Temp Applications
Greetings,
A reinforced concrete structure that I'm designing will be subjected to a permanent, sustained temperature of -20F for its entire design life. I plan to use A615 Grade 60 rebar.
To the best of my knowledge and research, there are no special precautions that I need to follow for the design and/or testing of the rebar as a result of this sustained low temperature.
Is anyone aware of any special precautions or requirements that I might have overlooked?
Thanks for any help you can provide.
Tankie
Tankie
RE: A615 Gr60 Rebar -- Low Temp Applications
