Seeking a lisp routine
I need a simple lisp routine that starts a polyline, set's it's starting width at 0.00 and ends at 3.00
The company I now work for uses such plines for pointers or leaders. Only they're doing it manually. Any help is appreciated.
SD
RE: Seeking a lisp routine
try a button Macro
^C^Cpl;\w;0;3;\w;0;0;;
paste above into Macro for new button
search threads for creating new button macro
hope this helps
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
view this thread for creating new button
Thread555-68450
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Fantastic Ozzie!!! Thanks, works like a champ~
ONLY...is there a way to make this command repeat itself after hitting enter? As of now it goes back to standard polyline command when repeated.
yes, if you add "*" before the rest of the macro
*^C^Cpl;\w;0;3;\w;0;0;;
this will repeat the command until [esc]
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Perfect! Thanks Oz.
