Zero Sequence Voltage 3Vo
Is Zero Sequence Voltage detectable through a Delta transformer winding? It appears that the Delta would block it the same as zero sequence current?
Is there any good references on applying zero sequence voltage protection settings?
RE: Zero Sequence Voltage 3Vo
http://
There also an article on the Basler web site about open phase detection which I believe discusses zero sequence voltages. I can't find it now because their site is down.
An grounded-wye/[b]broken[/b]-delta transformer set is one simple ‘zero-sequence filter’ used for 59N/59G ground-detection protective relaying. The Stevenson text and GE IAV and Allentown 59G relay ILs discuss applications on ungrounded and high-resistance-grounded systems.
See Thread238-57405 and do an advanced search in electrical fora under “broken delta.”
