Drape forming?
Drape forming?
Drape forming?
I had a question about trying to produce a plastic box.  It would resemble a milk crate, but made out of sheet ABS, and missing one of the sides.
The basket dimensions are 17"x26"x14".
I am obviously new to plastic forming techniques.
Is it possible just to drape form this part, or would a different process be needed.
Thanks for Any Suggestions
Best Regards,
Mark
RE: Drape forming?
What are the allowable tolerances?  What type of production volume is expected?  Any special finishes required?  More info is required.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Drape forming?
The production volume is 5,000 per year.  No special finish.  The tolerance in any direction is 0.10"
RE: Drape forming?
Depending on the material thickness, allowable draft angle and edge/corner radius requirements, it looks like this could be drape formed.  When you mention "milk crate" I start thinking mesh sides, integrated handles, nesting/stacking features, etc.  If this is the case, then drape forming won't work.  Another application would include rotational molding.
