Convert AutoCad R14 to PDF
I need to convert a number of existing AutoCad R14 drawings into .pdf format. I have both R14 and Adobe Acrobat 4.0 installed on my computer. The local AutoDesk retailer tells me that R14 didn't have this capability and AutoDesk no longer supports R14. So - I'd appreciate any recommendation for a work-around or for good quality reasonably priced (<$100) software that can do this task. The drawings need to look like the originals when viewed and when printed in 24" x 36" size.
Greg
Greg
RE: Convert AutoCad R14 to PDF
TTFN
I have not used it (or even seen it) but it supposedly opens "all" versions of AutoCAD & may have a PDF printer built in.
This would work if I didn't have some 10,000 drawings that may require conversion to PDF. I think asking that would wear out our friendship.
We use it on 5 machines and it works great. Good program with a decent price.
IDWT
Patrick
Unfortunately, CutePDF manages documents that are already in PDF format. I'm trying to get AutoCad drawings into PDF. But thanks for the reply.
What do you mean by "manages documents that are already in PDF format". I am using it to create pdf files from Solid Edge or from Word, so unless I misunderstood something it should work?
Bring back the HP-15
www.hp15c.org
http://www.soliddwg.com/
I don't have experience with it, but I use regularly another product of them: PDF to Word
