Ultra Low Noise FET Preamp
IFPA300 SPECS:
INPUT-REFERRED NOISE VOLTAGE = 0.6nV/rtHz@10kHz, 3nV/rtHz@10Hz
INPUT LEAKAGE CURRENT (@25C) = 10pA
INPUT CAPACITANCE (OL) = 60pF
OPEN LOOP GAIN (DC) = 85dB
GAIN BANDWIDTH PRODUCT = 200MHz
OUTPUT CURRENT (@25C) = 100mA
OUTPUT DRIVE CAPABILITY = 50ohm, 1000pF
MAX. AVG. POWER DISSIPATION = 225mW
POWER DERATING FACTOR = 1.8mW/C
MAX. OPERATING TEMPERATURE = 150C
PACKAGING OPTIONS = TO-99, SOIC-8
MANUFACTURER = interFET.com
I am currently in need of this inverting transimpedance IC from InterFET, but I don't have the volume or the budget for the NRE. You see, although InterFET developed and tested this part, the original customer went away, and so they haven't bothered to upgrade the masks for their current 4" wafer fab. If you or anyone you know of could use this part, please let me know, as you can still get samples for evaluation, and they perform like nothing else.
