Pilot Scale Hot Oil Systems
Greetings,
I need to purchase a small hot oil system for a pilot plant. Something on the order of 25 KW max and oil temperature in the neighborhood of 500 F. I am not familiar with these systems. Looking for some recommendations for a good reliable skid mounted self contained unit with pump and temperature control.
Anyone have experience with this?
Thanks in advance.
JoeChem
Thanks in advance.
JoeChem
RE: Pilot Scale Hot Oil Systems
I don't know what succes you've had with an internet search but rightly or wrongly, and lacking any specialist supplier data, I would start by looking at the companies who supply fuel oil heaters to the marine and power industries. These companies routininely design and supply fuel oil heater systems including all pumps, sensors and controls.
For example, you might try ELWA in Munich for electric oil heaters. They will design and supply a package including pumps, temperature sensors, control electronics etc.
Other such suppliers could be MAS (Germany)for steam or electric heater systems.
JMW
www.ViscoAnalyser.com
The unit could be self designed rather than procured as a skid. Essentially the system will include pumps, a heater, an expansion vessel and control\trip instrumentation. All of the components should be able to be bought of the shelf. Self design allows much greater flexibility, particulalry with regard to layout/space allocation.
The system should be arranged so that the expansion vessel is located at the high point of the system feeding the circulation pumps. The pumps will pump cold heating medium through the heater to the load (heat exchanger or vessel jacket) and back to the expansion vessel. Demand at the load should be controled by a simple temperature control loop. Any demand not taken up by the load should be recirculated back to the expansion vessel using a minimum flow bypass, i.e. even if the demand at the load is low the pumps will still be able to deliver a flow which prevents them from overheating. I'd recommend an electric heater. The expansion vessel could be open to atmosphere or pressurised with compressed air if there is a risk that the heating medium could boil at atmospheric pressure.
rgds
http://www.broach.com/
http://www.tfsheat.com/
Or if you go the do it your self approach here is a lot of information on Therminol.
http://www.therminol.com/pages/
Here is a list of equipment manufacturers of thermal heating fluid.
http://ww
