Convergence Problems
I have started using Abaqus few months ago, so this might be a simple problem but I can't solve it. In my model I must set a displacement of one rigid part that becomes in contact with a deformable part. But it only works when the displacement is small. When I use a large displacement the job is aborted because convergence problems.
What should I do? Is there anything to do with interaction properties?
Thanks..
RE: Convergence Problems
If it's failing in the first increment or two of the step, try setting a small initial displacement for the 1st increment of the step. For example:
*STATIC
** init'l  time period  min.       max.
** time    of step      time       time
   0.05,   1.00 ,  0.0000001 ,    0.20
sets the size of the initial increment to 5% of the total in the step. ABAQUS will increase the size of subsequent increments to a maximum of 20% of the step size if convergence remains satisfactory.
Are you using NLGEOM?
MRG
http://www.analysis.demon.co.uk
thanks mrgoldthorpe
I just didn't pay attention on the NLGeom.
Bra1
